changing resolution
jvas
changing resolution
Postby jvas » Wed Apr 15, 2015 7:04 pm
I'm really lost. How to change it. In XaAes, the change resolution menu item is grey. In teradesk, only the standard falcon resolutions ca be selected. On the firebee, there is modes.prg. Is there something similar exists for the SV?
Thanks,
Jozsi
HuggyOne76
Re: changing resolution
Postby HuggyOne76 » Sat Apr 18, 2015 8:19 pm
Have you try to change sv.inf ? There's an option for resolution and colors you want to run.
jvas
Postby jvas » Sun Apr 19, 2015 6:44 pm
Yes, that works fine. It is just a pity, that there is no resolution change app for SV (except what is in TOS desktop)
Postby shoggoth » Sun Apr 19, 2015 7:04 pm
jvas wrote:Yes, that works fine. It is just a pity, that there is no resolution change app for SV (except what is in TOS desktop)
Indeed. It's not rocket science, but someone has to write one :)
jvas
Postby jvas » Mon Apr 20, 2015 6:05 am
For the FireBee, someone has written "mode.prg". Maybe it could be modified/ported easily by someone who knows the hardware...
(SV_XBIOS should also contain the necessary code, since it enhances the original GEM desktop)
Postby joska » Mon Apr 20, 2015 6:32 am
jvas wrote:For the FireBee, someone has written "mode.prg". Maybe it could be modified/ported easily by someone who knows the hardware...
That "someone" would be me :) The FireBee resolution selector is 100% XBIOS dependant. It does not know anything about the hardware, but depends on information from XBIOS. FireTOS use a variant of the XBIOS extensions from Milan TOS. If Didier (or the SuperVidel developers) would implement the necessary SuperVidel XBIOS support then modes.prg would work without modifications.
If anybody wants to use modes.prg as a basis for a SuperVidel resolution selector they are free to do so. The sources are freely available. But only the GUI code would be of interest, and since it's a pretty simple GUI it would probably be less timeconsuming to write something from scratch.
jvas
Postby jvas » Mon Apr 20, 2015 7:13 am
Does it crash, because of the missing xbios functions or because it was compiled for the FireBee?
Postby joska » Mon Apr 20, 2015 7:36 am
It crash because FireTOS returns weird/undocumented data when modes.prg queries for screen modes.
Postby shoggoth » Mon Apr 20, 2015 9:03 am
joska wrote:That "someone" would be me :) The FireBee resolution selector is 100% XBIOS dependant. It does not know anything about the hardware, but depends on information from XBIOS. FireTOS use a variant of the XBIOS extensions from Milan TOS. If Didier (or the SuperVidel developers) would implement the necessary SuperVidel XBIOS support then modes.prg would work without modifications.
Basically, the SV has a TOS4 video XBIOS, with *some* additions. In the end, I chose not to clone the CTPCI API, because I could se no benefit of doing so. It supports some mode enumeration function, and allocates video ram the same way, but apart from that, it's TOS4/Falcon, with some new bits added to the modecode. If modes.prg works on std Falcon video, it could easily be extended to support the SV.
Return to “SuperVidel”
