Boiler / Blitter and Memory Browser bug
Postby Cyprian » Sun Mar 08, 2015 12:23 pm
I'm testing some blitter routines. I have open Memory Browser with location where blitter copies the data (destination point). Initially that part of memory is filled with 0's .
When I put a breakpoint after blitters code and run it, then I see valid new data in that Memory Browser. But when I use "Trace Into" button, Memory Browser isn't refreshed and shows old data - 0's.
Re: Boiler / Blitter and Memory Browser bug
Postby Cyprian » Sun Mar 08, 2015 11:19 pm
Steven,
it seems that issue exists also after pressing "RUN" button. Below you can find screnshoots done after each of thee breakpoints.
The first one is before blitting process, the second one is after blitting, and the third one is after saving the result to the file BLIT.BIN
Blitting is invoked at address 00F1EC - "move.b #$c3,60(a6)", and should be done before "nop" at 00F1F2
The Memory Browser window after the first breakpoint looks ok - there are only 0's. The Memory Browser after breakpoint 2 (after blitting) should be the same as after breakpoint 3 but it doesn't.
Breakpoint 1
Breakpoint 2
Breakpoint 3
Postby Steven Seagal » Thu Mar 12, 2015 9:09 am
When you're stepping, Steem considers itself stopped.
Because of a test for "run state" in the blit procedure, the blit just doesn't happen.
I can fix it, but it looks a bit "dangerous" to me, though if it's boiler-only...
#ifdef TEST01
  while (1 ){
    while (cpu_cycles>0 && 1){
#else
  while (runstate==RUNSTATE_RUNNING){
    while (cpu_cycles>0 && runstate==RUNSTATE_RUNNING){
#endif
Postby Cyprian » Thu Mar 12, 2015 11:23 am
I've checked that, and this issue happens only when a breakpoint is set at the next instruction after blitter start.
When I set a breakpoint at the first NOP in that case below, MOVE will see 0's (initial value). But when a breakpoint will be at the second NOP, MOVE will see proper, blitted value.
   move.b #$c3,60(a6)      ; Do Blit
   nop
   nop
   move.w   $4E(A4),D0
OK, I can live with that workaround.
Return to “Development”
