AGA core for mist
vebxenon
Re: AGA core for mist
Postby vebxenon » Mon Feb 22, 2016 7:27 am
chaos wrote:
breiztiger wrote:hi
i don't know if it's at the right place ...
http://www.pouet.net/prod.php?which=65405
this demo have some glitchs at part 3, flying objects, some garbage on graphics
breiztiger
This demo is fixed in the new release:
http://somuch.guru/minimig/minimig-mist/
Oustanding news!!! :cheers: :cheers: :cheers: I'm going to download it when I'm back home.
Thanks for your great work. I even sold my A1200 because of this core.
Regards,
Salva
- Atari Jr 2600 clone
- Atari 7800 Peritel
- Atari XEGS
- Atari Lynx II
- Atari Jaguar
- MiST Board
quest2
Postby quest2 » Mon Feb 22, 2016 9:15 am
Awesome job :)
Tested the new features with the Multiscan monitor driver, and the 640x480@58Hz is working very well (have to change the cursor to a High-res one). The right side line of pixels issue is not too problematic. No more flicker in high res :D
Only one issue: In 640x480 Multiscan mode, the OSD is "broken", as it is now off scren (you can see it about 1/4 of the OSD window on the right side of the screen, but obviously it is unusable)
Thank you! :cheers:
mahen
Postby mahen » Mon Feb 22, 2016 4:49 pm
I spend a little more time with it : huuuuge compatibility increase here (including many games that had currupt gfx) !!
I only saw one tiny regression : WizKid game (WHDLoad) works with the 1.1 core, but I get a black screen with the 1.2 core. I'll try to make a list :) Apart from very few titles, the only remaining issue I have is with the games giving startup errors like "line 1111 emulator".
As my Iiyama screen didn't appreciate the DblPAL modes (48 Hz : not supported) I tried the other monitors. I got the Euro72 monitor to work (non-interlaced 640x400), pretty good !
Again, awesome work, Chaos :-) You deserve a lot of rest !
vebxenon
Postby vebxenon » Mon Feb 22, 2016 8:11 pm
How do you enable DbLPAL or Euro72 resolutions?
- Atari XEGS
- Atari Lynx II
- Atari Jaguar
- MiST Board
mahen
Postby mahen » Mon Feb 22, 2016 8:40 pm
Move the monitor files from Storage:DEVS/Monitors to DEVS:Monitors
You can double click to test them without rebooting. Before saving make sure your screen supports those modes. (mine doesn't like 48 Hz DblPal :)
quest2
Postby quest2 » Mon Feb 22, 2016 8:57 pm
Better try Multiscan resolutions (I moved MULTISCAN file from storage to devs/monitors) then you get 640x480 at 58Hz. 99% of vga monitors support that ;)
mahen
Postby mahen » Mon Feb 22, 2016 9:09 pm
Are some "monitors" supposedly slower than others ?
vebxenon
Postby vebxenon » Mon Feb 22, 2016 11:26 pm
Thanks! I didn't remember how to do it. I'm going to try them :D
By the way, Have you tested Super Off Road WHDLOAD? Is one of the few few games I'm unable to play, like Pierre is Out of Lunch and Pinball Illusions.
But for example Alien Breed 3D, All New World of Lemmings or the Nexus 7 demo work better than ever :D
Regards :cheers: :cheers: ,
Salva
- Atari XEGS
- Atari Lynx II
- Atari Jaguar
- MiST Board
vebxenon
Postby vebxenon » Tue Feb 23, 2016 12:38 am
Also R-Type II is unplayable but it's not a Minimig fault, is a WHDLOAD fault, because even on WinUAE game has severe graphical problems.
- Atari XEGS
- Atari Lynx II
- Atari Jaguar
- MiST Board
vebxenon
Postby vebxenon » Tue Feb 23, 2016 7:28 am
Well, I've done more testing at night, and I've noticed that too many ECS-OCS games run now TOO fast. Playing using WHDLOAD Shinobi, Sidearms, Soldier of Light, Space Harrier II or even the slow Street Fighter II for example is near impossible, everything is fast, so it seems that there is some problems with timings. I haven't tested yet playing these games using ADF disks, but actually I prefer to play from the hard disk. Have you seen the same problem?
At evening I'm going to open these issues at https://github.com/rkrajnc/minimig-mist/issues
Regards,
Salva
- Atari XEGS
- Atari Lynx II
- Atari Jaguar
- MiST Board
mahen
Postby mahen » Tue Feb 23, 2016 8:03 am
Guys, before reporting a bug, please double check under uae and a similar config.
Indeed whdload installs are often at fault ! And adf versions often have troubles because games weren't meant to be used on a fast aga machine...
vebxenon
Postby vebxenon » Tue Feb 23, 2016 8:53 am
mahen wrote:Guys, before reporting a bug, please double check under uae and a similar config.
These games are the same I had and played in my now sold A1200 which had a 68030 50 MHZ and 64 MB RAM. And in previous cores worked well. I've never had any problem with timings, except in JIT enabled emulators. I'll try NOCACHE option, an option I've never used.
- Atari XEGS
- Atari Lynx II
- Atari Jaguar
- MiST Board
Amedia
Postby Amedia » Tue Feb 23, 2016 12:58 pm
Hi ;)
Very good work but Bubble Heroes has still some big graphic's glitches (with or without turbo mode, or with or without cpu caches in KS3.1) and Pinball Illusions still crashes after launching any table.
Thanks, Laurent and Franck
Amedia Computer
Laurent - Faranheit
Amedia Computer
Amiga software and hardware / FPGA Clone reseller
69, Avenue de la Libération
F-57530 Courcelles-Chaussy
France
Site : http://amiga.amedia-computer.com
Mail : laurent@amedia-computer.com
Fenio
Postby Fenio » Tue Feb 23, 2016 2:49 pm
vebxenon wrote:Also R-Type II is unplayable but it's not a Minimig fault, is a WHDLOAD fault, because even on WinUAE game has severe graphical problems.
This is not a problem with WHDLoad but AGA in minimig on new core. R-Type II works fine on ECS settings. ADF version also has problems with graphics if is active AGA. In the present core some games such as. Battle Squadron which in previous cores work fine on AGA do not work properly with the latest core. The solution is to set the OCS / ECS and reset.
Whdload version Pinball Illusion (AGA) crashing after launching table with error:
vebxenon
Postby vebxenon » Tue Feb 23, 2016 9:31 pm
Oh, yes, you're right, using previous core, minimig-mist-1_1_20160125.rbf, https://github.com/mist-devel/mist-bina ... 160125.rbf I'm able to play perfectly R-Type II, Shinobi, Sidearms...
Hope this AGA problem will be fixed soon.
Regards,
Salva
- Atari XEGS
- Atari Lynx II
- Atari Jaguar
- MiST Board
Fenio
Postby Fenio » Tue Feb 23, 2016 9:43 pm
For example on Battle Squadron it looks identically* as the problems with enabled turbo for chipram with previous cores. Despite the fact that turbo for chipram is disabled.
* - viewtopic.php?f=101&t=27110&p=273584&hilit#p273584
vebxenon
Postby vebxenon » Wed Feb 24, 2016 8:03 am
I've reported the problem with the timings at https://gitreports.com/issue/rkrajnc/minimig-mist :cheers:
Regards,
Salva
- Atari XEGS
- Atari Lynx II
- Atari Jaguar
- MiST Board
Fenio
Postby Fenio » Wed Feb 24, 2016 6:55 pm
Did you check these games on ECS chipset without turbo (turbo - none) ?
chaos
Postby chaos » Wed Feb 24, 2016 10:45 pm
it seems the CPU-chipRAM speed is too fast in the minimig-mist 1.2 even without the Turbo option. It's going to take some time before this is properly fixed, so for now, here's a test version of the minimig core which has the same speed as the v1.1 version when turbo is off.
http://meditation.somuch.guru/minimig/f ... 160224.zip
** my minimig builds: http://somuch.guru/ **
vebxenon
Postby vebxenon » Wed Feb 24, 2016 11:52 pm
chaos wrote:Hi,
Oh, thanks! :cheers:
I'm going to test it before I'm going to bed.
Regards,
Salva
- Atari XEGS
- Atari Lynx II
- Atari Jaguar
- MiST Board
Fenio
Postby Fenio » Fri Feb 26, 2016 10:10 am
Does anyone use X-bEnCh for whdload game ? Also have a black screen with pointer after quit x-bench ? The problem occurs only if you run a games, then exit the program. X-Bench v0.99 R7 from http://www.jimneray.com/xbench.html
AmigOS2
Postby AmigOS2 » Mon Feb 29, 2016 1:49 am
I am quite new to the MIST. Could anyone please let me know how to update this new build (minimig-mist-v1.2 (2016-02-21))?
Thank you.
Postby Newsdee » Mon Feb 29, 2016 6:44 am
You need to both update the core.rbf file and the firmware. Instructions are in the wiki (so check details) but to summarize:
1) upgrade firmware from inside the old core (via OSD menu)
2) (optionally) copy the old core file in your SD card as a backup
3) replace with new core file on the SD
I did this over the weekend and everything worked as I left it (it should keep the old config)
mahen
Postby mahen » Mon Feb 29, 2016 8:39 am
Fenio : I didn't have a good experience either with xbench / tinylauncher. They are still buggy imho (I could elaborate... The biggest issue being hd devalidation with tl !!). That's why I start games via the WB but I had to manually select a subset of games otherwise it'd be too slow... At least it makes it easy to select whdload options, tooltypes, you can make custom categories and icons are gorgeous with newicons...
Amedia
Postby Amedia » Mon Feb 29, 2016 8:51 am
@Mahen:
AGLaunch integrated in Classic Workbench 3.1 is very good too ;)
Amedia Computer
Laurent - Faranheit
Amedia Computer
France
