MiST core and firmware changelog
Sheldon
Re: MiST core and firmware changelog
Postby Sheldon » Tue Aug 20, 2019 4:45 pm
Great Good news ,Mist still Alive :D
slingshot
Postby slingshot » Tue Aug 20, 2019 8:01 pm
firmware_190820
- Minimig fixes from retrofun, missed in yesterday's release
uchristo
Postby uchristo » Mon Oct 07, 2019 9:48 am
Asked this some time ago on mist-fpga.net....
Is it possible to attach XBOX360 Wireless-Adapter to MiST ( https://github.com/felis/USB_Host_Shield_2.0 ) or even include code for Bluetooth-Dongles into Firmware?
MasterOfGizmo
Postby MasterOfGizmo » Mon Oct 07, 2019 10:33 am
uchristo wrote:Is it possible to attach XBOX360 Wireless-Adapter to MiST ( https://github.com/felis/USB_Host_Shield_2.0 ) or even include code for Bluetooth-Dongles into Firmware?
This would require two things
    a. A complete bluetooth protocol stack and
    b. A user interface for device selection, pairing etc
Both is sure possible but a lot of work ... and flash space is limited, so one might have to optimize a lot.
slingshot
Postby slingshot » Sat Nov 02, 2019 8:28 pm
firmware_191102
- Unused cart area is pulled up in ST cores
- Multiple profiles support for ST cores
- Archimedes IDE interface support
- Changed 24MB Fast RAM option to 8MB in Minimig's 68000 mode
gregoryMJM
Postby gregoryMJM » Wed Nov 20, 2019 11:40 am
slingshot wrote:Multiple profiles support for ST cores
Thank you! ❤️ :cheers:
Marijuana Mail 0.1.77, an e-mail client for Atari 1040ST and TOS 1.0:
http://atari.net.pl/mjm-en
slingshot
Postby slingshot » Fri Nov 29, 2019 7:01 pm
firmware_191129
- Direct SD->FPGA transfer for MiSTery ACSI (core update needed)
- Direct SD->FPGA transfer for other cores' ROM upload (core updates needed)
- Some minimig and OSD related fixes from Retrofun
- More complete input device test OSD
jamesrc
Postby jamesrc » Fri Nov 29, 2019 8:29 pm
slingshot wrote:firmware_191129
The .upg file does not appear to be here:
https://github.com/mist-devel/mist-bina ... r/firmware
Although the old Firmware was moved to the old folder.
DrOG
Postby DrOG » Sat Nov 30, 2019 6:13 am
Thank you!
rondc
Postby rondc » Sat Nov 30, 2019 9:35 am
Thanks ! :D
uchristo
Postby uchristo » Mon Jan 06, 2020 1:45 pm
maybe a stupid question....
is it possible to "pause" the MiST with a customiseable keyboard-shortcut (e.g. ctrl+alt+delete)? Entering the OSD doesn't pause the simulation. Is it in general possible to do such thing independently from the core?
slingshot
Postby slingshot » Mon Jan 06, 2020 1:47 pm
uchristo wrote:maybe a stupid question....
No, it''s not possible. Even it's tricky in the core level.
ManuFerHi
Postby ManuFerHi » Wed Jan 22, 2020 10:53 pm
The firmware could be modified so that the roms are always in ROMS directory and .cfg files also in CONFIG directory, I have an SD with all the cores sorted by directories, but the root directory is a chaos with all the roms of arcades and .cfg
Sheldon
Postby Sheldon » Wed Jan 29, 2020 8:21 pm
With last Mist Firmware 20191129 : Usb Joypad issue : don't work. there are 6 joystick in the list but all in Atari 1 button mode
need to comme back to Firmware 20191102 in order to have usb pad with 6 buttons in core.
slingshot
Postby slingshot » Thu Jan 30, 2020 10:27 am
Sheldon wrote:With last Mist Firmware 20191129 : Usb Joypad issue : don't work. there are 6 joystick in the list but all in Atari 1 button mode
If the list shows 6 DB9 joysticks, then it's surely a bug - in the device insert/remove code. I've seen it once when I rapidly plugged in/pulled out joypads. But that part wasn't really changed. What kind of USB pad is it? Try to plug in, then turn on MiST.
Sheldon
Postby Sheldon » Thu Jan 30, 2020 12:40 pm
with previous firmware 20191102 all works well : sega cores, nintendo cores, amiga core with this pad: https://www.amedia-computer.com/en/joys ... 41793.html
but with last firmware: nothing works with the same pad :)
i will test you say tonight.
slingshot
Postby slingshot » Sat Feb 08, 2020 8:11 pm
firmware_200208
- Support Arduino based keyboards
- Add csync_disable option to mist.ini
- Fix ini_parser for mist.ini files > 1024 bytes
- Introduce ARC metadata files (mostly for arcade usage)
DrOG
Postby DrOG » Sun Feb 09, 2020 4:48 am
Thank you for your overall support of this platform! :cheers:
brunosilva
Postby brunosilva » Sun Feb 09, 2020 9:08 am
hi
thanks for the new firmware. its possible to a some features? :)
- add path to rbf in .arc file (do we can have arc file in different path - now i have in the "core list" two scramble)
- possibility to add only part of the filename of the core in arc file (scramble in arc for scramble_20200209.rbf filename)
- possibility to have a /rom folder where we place the roms - rom files in root of sdcard will continue to grow (for example, mist will try to find first rom file in /rom folder and after that in root folder)
slingshot
Postby slingshot » Sun Feb 09, 2020 9:16 am
brunosilva wrote:- add path to rbf in .arc file (do we can have arc file in different path - now i have in the "core list" two scramble)
With the current FAT driver, it's required to have the short 8(+3) name in the ARC file. Wildcard matching and such are not really feasible (nor I want to do it). The other requests - have to think about a proper implementation.
DanyPPC
Postby DanyPPC » Sun Feb 09, 2020 3:44 pm
What affect this option ?
hyperterminal
Postby hyperterminal » Sun Feb 09, 2020 4:14 pm
csync_disable=0 ; set to 1 to output separate hsync and vsync in 15khz
slingshot
Postby slingshot » Sun Feb 09, 2020 4:31 pm
If you have a 15kHz monitor which doesn't like composite sync, then set it to 1. However now only the new Minimig and MiSTery cores support it.
DanyPPC
Postby DanyPPC » Sun Feb 09, 2020 4:42 pm
Many thanks to you for the explanation.
DrOG
Postby DrOG » Mon Feb 10, 2020 5:26 am
Thanks for implementing this useful feature on both firmware and core levels! :cheers:
Users browsing this forum: eeun and 5 guests
