Hatari on tablet device
Omikronman
Re: Hatari on tablet device
Postby Omikronman » Fri Jul 07, 2017 9:15 am
It is working now. I think it has something to do with the Android 5 mounting the SD card write protected for an unknown reason. Copying the Atari files to the internal storage made it working.
Omikronman
Postby Omikronman » Sat Jul 08, 2017 9:33 pm
mh O.o
mistralblue
Postby mistralblue » Sun Nov 26, 2017 7:26 pm
Hey guys - just come across Hatari on both PC and Android. I'm sure those of us 80s kids will understand the joy of booting Xenon 1/2, Stunt Car Racer, Robocop etc again for the first time in about 25 years!
Question for the Android version Dev if I may, I've installed it on my girl's tablets to introduce them to some proper gaming. Problem I am having is with Bluetooth controller mapping. Each tablet (Hudl2) will recognise the controllers as separate entities (and I can even name them as such). Hatari android app can only map one device, if I map pad 1, as soon as I map pad 2 it robs the assignments to pad 1 (basically means I can't use two bluetooth pads). I tried again with a completely different model of bluetooth pad and it did the same thing, suggesting it is the app that is having issues differentiating between the two different pad inputs. Not sure that there's anything that can be done about this but would be great if it could be fixed! Other than that, its AWESOME! Thanks for all your hard work... :D
squall
Postby squall » Mon Nov 27, 2017 1:30 am
Hi mistralblue,
I'll have a look at the two player support once I get some time to start working on the android version again.
mistralblue
Postby mistralblue » Mon Nov 27, 2017 3:58 pm
Sweet thank you! You've made a 37 yr old and x2 6 yr olds very happy with your efforts thus far anyway :))
tyk
Postby tyk » Thu Mar 08, 2018 10:01 pm
I have write some Hatari instructions to old good Nokia pocket tablet devices:
https://talk.maemo.org/showthread.php?t=100121
Postby Cyprian » Tue Feb 05, 2019 7:46 pm
would be possible to hide an android mouse cursor when a user uses the real mouse?
now I can see two mouse pointers - android one and the GEM one, and sometimes they are placed in a different positions
squall
Postby squall » Sat Feb 09, 2019 6:16 am
I haven't looked into it yet, but it's not possible before Android Nougat (without custom firmware).
Android Nougat finally added some support for overriding the mouse cursor icon so I can probably set the cursor to a transparent bitmap to make it not visible for newer versions of Android.
Postby Cyprian » Sun Feb 10, 2019 11:46 am
ok thx
Return to “Hatari”
