Steem SSE 3.6 bug reports
Postby Steven Seagal » Mon May 27, 2013 5:17 pm
For each version I would now open a "coming soon" thread to announce new features, and a "post-mortem" thread to welcome bug reports.
So, anything wrong in Steem v3.5.X, please report here.
Edit: tried to change the name of the thread, I have the feeling post-mortem isn't clear to everybody.
Edit: changed for v3.6
Last edited by Steven Seagal on Tue Mar 11, 2014 6:52 pm, edited 2 times in total.
Zorro 2
Re: Steem SSE 3.5 post-mortem
Postby Zorro 2 » Wed May 29, 2013 2:18 pm
Noting special from this version, you are just the best !
Many thanks mister Steven Seagal :D
Member of NoExtra Team
Postby DrCoolZic » Mon Jun 10, 2013 8:22 am
Do not know if this is done on purpose but...
- After a "Release Mouse" it used to be that you just had to click anywhere in the Steem emul windows to "take over mouse". In 3.5.0 you need to click the arrow run in upper left. This is OK but annoying.
- I have placed the Steem 3.5.0 executable in a directory where Steem 3.2 was run. I started 3.5.0 exec, did a reset, and clicked run but Steem never started. I had to remove several state and the .ini file to make it work?
EDIT
- Interesting I thought the version of 3.5.0 that I have build was not working. But in fact the problem was with this state files! Now version done with VS2012 is working fine
- FYI: I still have a problem with the debug build. The program crash and when i start the VC++ debugger it breaks on an assert line 246 of fdc.cpp : ASSERT(shifter_freq==50) if I continue it works fine untill next time it reaches the same assert (related to motor spin up time)?
Postby Steven Seagal » Mon Jun 10, 2013 5:14 pm
DrCoolZic wrote:Do not know if this is done on purpose but...
EDIT
- For mouse, check SSE option page 'Capture mouse' and General page 'Start emulation on mouse click', it could be unchecked.
- When you have strange crashes, it may be a good idea to delete auto.sts, sometimes it really messes up. Ini should be safer.
- The ASSERT you mention, it was because 'accurate' mode was assumed to operate at low res for games/demos in 3.5.0.
I made something better in 3.5.1.
Postby DrCoolZic » Mon Jun 10, 2013 6:51 pm
Thanks for info
ecureuil
Postby ecureuil » Mon Jun 24, 2013 12:57 pm
I have seen you tagged the v3.5.1.linux. This version seems not compile with my ubuntu? Could you confirm or infirm it because i will interested to build SSE on Linux for my usage.
Postby Steven Seagal » Sun Jul 07, 2013 9:56 am
I have looked at Crackdown STX 2 disks.
It doesn't work in Steem 3.2, 3.5.1, nor in SainT 2.20.
I suspect the image is wrong because the one disk version works. Of course, not sure.
Shazz
Postby Shazz » Sun Jul 07, 2013 4:48 pm
Thanks for your work !!! Really.
Is it possible to have a little change when screenshots are generated :
file : display.Cpp
line : 1384
if (AddNumExt){
int Num=0;
do{
if (++Num >= 1000) return DDERR_GENERIC;
ShotFile=ScreenShotFol+SLASH+FirstWord+"_"+(EasyStr("000")+Num).Rights(3)+"."+Exts;
}while (Exists(ShotFile));
Can you or increase the "1000" value to anything bigger (10000 ?) + "000", or better to make it configurable ?
999 => only 20s of data....
...8bits are enough...
dlfrsilver
Postby dlfrsilver » Sun Jul 07, 2013 7:59 pm
Steven Seagal wrote:I have looked at Crackdown STX 2 disks.
Or exactly, what the original 2 disks release is searching for ?
Postby Steven Seagal » Sun Jul 07, 2013 9:04 pm
Shazz wrote:Hi,
file : display.Cpp
line : 1384
if (AddNumExt){
int Num=0;
do{
Sure, it seems easy. Configurable, maybe not.
Postby Steven Seagal » Sun Jul 07, 2013 9:07 pm
At this point I don't know anymore than what I stated. The simplest case is "bad disk image". If the image is correct, it could be harder to find.
Postby Steven Seagal » Sun Jul 07, 2013 9:24 pm
ecureuil wrote:Hello,
I've just uploaded a file "Building Linux SSE.txt" in the X-build folder, this was missing... :(
[r41] Linux build info
dlfrsilver
Postby dlfrsilver » Sun Jul 07, 2013 9:40 pm
The protection is failing. What i remember when i made the STX images, is that my original disks were pferfectly working (it was a sealed copy when i bought it).
Postby Steven Seagal » Sun Jul 07, 2013 9:53 pm
dlfrsilver wrote:The protection is failing. What i remember when i made the STX images, is that my original disks were pferfectly working (it was a sealed copy when i bought it).
The disks may be good and the images may be bad, I don't know if that's the case, but it happens.
When you say "the protection is failing" do you know for a fact that it acted like this when failing?
dlfrsilver
Postby dlfrsilver » Mon Jul 08, 2013 1:56 am
Yes, i remember sending the STX images to an amiga cracker (the ST release has many things which were not implemented in the amiga release).
He has more or less hinted me about an emulator problem. Not that the disk images were wrong..... Maybe dr coolzic could take a look at this one ?
Shazz
Postby Shazz » Fri Jul 12, 2013 7:43 pm
Cool ! Please let me know when available :)
Steven Seagal wrote:Sure, it seems easy. Configurable, maybe not.
Postby Steven Seagal » Sat Jul 13, 2013 4:52 pm
Shazz wrote:Cool ! Please let me know when available :)
In fact it's already in the current beta. :)
dlfrsilver
Postby dlfrsilver » Sat Jul 13, 2013 9:53 pm
EDIT : after looking a bit, this game uses an 11 sector format (11x512 bytes per track). There is a short protection track in track 79.0 on disk 1, and there is another one on disk 2.
Maybe this one use a flakey bit protection ?
Postby Steven Seagal » Sun Jul 14, 2013 8:34 am
dlfrsilver wrote:EDIT : after looking a bit, this game uses an 11 sector format (11x512 bytes per track). There is a short protection track in track 79.0 on disk 1, and there is another one on disk 2.
Normally Pasti can handle all those things.
But if it somehow fails, there's nothing we can do, it's a black box.
Postby DrCoolZic » Fri Sep 13, 2013 9:32 am
Question:
If I do not have any disk in drive A then the system boot from drive C (the option When drive A is empty boot from C is set in Hard Drives form). In this case the programs located in AUTO folder are executed as expected.
Now if I mount a "blank" (just formatted) FD (using .st image) in the Disk Manager form and reboot the system, the system still boot from C drive? Is this normal? Even more strange in this case even though it uses the DESKTOP.INF file and mount the C drive it does not excute any programs located in the AUTO folder ???
Postby Steven Seagal » Sat Sep 21, 2013 3:49 pm
DrCoolZic wrote:Question:
Thx for the report.
I've already seen strange behaviour with HD/boot.
One day I'll look into it.
Postby AtariZoll » Sat Oct 19, 2013 7:41 am
Considering that strange boot behaviour: it is actually TOS imperfection, to say so. During warm boot, system variable bootdevice remains as C, after C boot session, and will boot from hard disk, again. Correction in Steem would be to delete (set to A) that system variable when there is regular floppy in drive A. Or disable C in some way ...
Postby AtariZoll » Sat Oct 19, 2013 7:42 am
Blerk
Re: Steem SSE 3.5 bug reports
Postby Blerk » Thu Nov 28, 2013 7:31 pm
Bit of a strange regression, but... if you turn on the 'record' option in the sound control panel to record ST output to a WAV file you can no longer hear any sound coming out of the speakers in (at least) 3.5.3 and 3.5.4. The sound does record okay to the file but if you can't hear what's being recorded it's a bit difficult to know when to stop. :)
This did work okay in 3.5.0 (I've still got a copy of that kicking around for when I want to record).
Thanks for all the hard work updating Steem, it's great to see it up and running again!
Postby Steven Seagal » Sun Dec 08, 2013 8:57 am
Blerk wrote:Hi,
Thx for reporting, I'll check and certainly debug for next version!
Return to “Development”
