Atari st series computers conversion PC
magic_gun
Postby magic_gun » Tue Oct 27, 2009 6:45 pm
hello friends,
I wanted to convert to pc atari st 1040 machine (this was my dream since a long time)
me and my team have accomplished and wanted to share with you
detailed pictures and my other projects
http://www.atariturkiye.com
finding retro mod sheet
respect and love sincerely
AtariSince1989
Re: Atari st series computers conversion PC
Postby AtariSince1989 » Tue Oct 27, 2009 11:30 pm
magic_gun wrote:hello friends,
Very nice work. I guess you're missing some keys when on the PC, right? But, even that I would like to have one :wink:
- Atari 520 STe 4MB RAM + TOS 2.06 + UltraSatan
- Atari Falcon030 14MB RAM + TOS 4.04 + IDE-SD card HDD + NVRAM mod + SCSI buffer clock mod + EtherNEC
- Amstrad CPC 6128 + HxC USB Floppy Emulator
- Acorn A3010 4MB RAM + 40MB IDE HDD
Atari ST Essential software (The List)
My FTP Server: http://www.datavase.info/FTPserver (only from Midnight to 8am UK Time)
My music at http://soundcloud.com/datavase/
Postby joska » Wed Oct 28, 2009 8:13 am
Very nice! That keyboard PCB is very impressive indeed. Why did you choose this instead of just converting the ST keyboard protocol to PS/2 using a microcontroller?
Btw that mouse conversion is nice. I converted a broken Atari mouse to PS/2 (for my Milan) the same way, but yours look nicer.
Postby wongck » Wed Oct 28, 2009 11:12 am
Would run an emulator on this rather then just Windoze.
magic_gun
Postby magic_gun » Wed Oct 28, 2009 7:17 pm
@ AtariSince1989
As you think
in some key, some keys are missing and more :)
in general use, but not much difference
thanks
@Joska
I first thought :idea:
Like you said you was to make a MC with a protocol converter
but the original ATARI ST keyboard controller (68hcXX) was broken :angel:
as a result, i was make a complete keyboard control pcb with pic 18FXXX
thanks
simbo
Postby simbo » Wed Nov 11, 2009 3:23 am
i like it
you can have a nice machine and do like this guy did
some keys missing for pc yes
but fly usb keyboard also fixes this
retain atari or any keystyle and board . for emulators and case reuse
i dont like throwing a case away...
very nice
very expandable unlike fpga clones
i have a couple of cases and a couple of keyboards so i guess ill be pm'ing you for your pic sources or hex
as it makes it easier....
top marks from me for one...!!! ill need to steal my micro atx board back from my pal
dead atari cases deserve a fitting home ...!!!
or a fitting pc deserves an atari case
but i guess im not allowed to say that [smilie=greencolorz4_pdt_04.gif]
as i have a spare falcon case becouse ill rehome it to another case maybe wooden ...
simbo
Postby simbo » Wed Nov 11, 2009 3:43 am
http://cgi.ebay.co.uk/Biostar-MCP6PB-M2 ... 439b0b4660
here is a £35 choice in ebay inc post
uses an amd dual core chip or other amd....
so total cost is cpu ~£50 + 35 board + memory ~ 45 for 2X1gb strips
no need for vga card etc only hdd and etc to find and build
very nice...
ill buy one of these boards tonight save bothering my pal
got one on its way
now the cpu....
ram
the new price of 2X2gb ram is around £40 per 2gb strip
ebay
http://cgi.ebay.co.uk/Kingston-HyperX-4 ... 3ef9f681b3
or look around
there is no point under populating it for want of a few quid
use the lowest watt's cpu and fastest speed and a many core chip {this board supports quad etc am2..X}
and a good atx psu i feel a good fan overall maybe two {back to the dam fans}
need to look at water cooling now... or peltiers also
simbo
Postby simbo » Wed Nov 11, 2009 4:31 am
on another closely related matter
i have an old sm124 dead crt why do people insist on throwing them away...???
so i took the board from it before for parts
now i have a crt and a case
the plan is to remove the crt
and use only the front panel from the monitor and trim off any plastic back to a flat reat plane
to house a 10" colour lcd can have vga or svideo or rgb scart input
you get these on ebay they are used for incar stuff portable dvd
can even have a dvd and also satnav in place touch screen is the plan
as you can use a pest to encode up the touch screen to atari mouse....
and also planes and trains... displays
and are easy to find for a 10 er or two
so take its front shell off its screen and mount it and adjust and panels to suite
ill look around
then just add a small stand from another montior or etc and a back panel as a cover reusing screw position posts
i plan to allow a switch on the monitor for hires
{audio in pin} of the atari
this pin can be reused for a voltage signal as its dc decoupled internal to the stX
so detecting the signal from the hires switch on the monitor
triggers a reset from the atari ,... a small connection inside ....
from pin 5 video socket rear to the reset button center pin
modification to rear of video socket
is
add a wire between pin 5 and the center pin of the reset button
as it will have a pull up effect just connecting one wire
now when you place pin 5 to ground
the reset of the machine will occur when if forinstance you switch over the monitor switch
stx and ste will benifit from this
sequence should be
pull pin 2 low reset via pin 5 a negative going pulse from a schmit trigger ic
to switch to hires and also use vga socket on the lcd unit
as there is a need maybe most however will auto detect avalbile signals
and default to them some even allow preset socket priority
even have wifi remotes
so to sum up
look for a kicj ass svideo , rgb scart , vga , inputs lcd 10"
perferably with satnav touch screen wifi remote mp3 4 player dvd and
multi language etc
there is the ultimate sm124 / 5 project as sized
im gona do it in the next few months
i dont have the cash this week but here is a little ditty perfect for the job
has nothing fancy using a touch tablets just as good as on screen
it will use AV for med / low and vga for high res i see it has av and vga input
reuse the vga.. input
http://cgi.ebay.co.uk/Super-10-inch-lcd ... 2303c6102d
snap it up for 20£ or so
has a remote
watch tv flip back to atari to check how the files are doing
magic_gun
Postby magic_gun » Thu Nov 12, 2009 6:57 pm
Dear atarians
Thank you very much. for your intersting :D
We are upgrading our web.
In this case you can join our forum and give your advise.( very important for us)
Best Regards.
atari turkiye team
http://www.atariturkiye.com/atari-forum.html
Postby wongck » Sat Nov 14, 2009 12:42 am
magic_gun wrote:Dear atarians
Best Regards.
atari turkiye team
Who are those gals painting that Atari logo?
alexh
Postby alexh » Sat Nov 14, 2009 10:50 am
If you're going to buy a AM2+ motherboard then you _MUST_ get a 785G based motherboard. Only £10 more, all other IGP based chipsets pale into insignificance on 3D scores next to it (admittedly they are still pretty poor compared to cheap PCIe card). Plus having an SB710 southbridge means you can attempt to unlock the 2nd core of a £25 Sempron 140 (assuming it is not broken) which can save you even more money.
simbo
Postby simbo » Mon Nov 16, 2009 1:08 am
hi alex thanks for the advice
i dont see 3d games being a problem for me
one idea for this use of such as this board is to use a right angle riser from pci and also pci
the pci for a tv card the pcie for video or video capture and output card {realtime one}
i think any old chipset and a nice fitting board is cool
i do agree some are better than others but im sure with time
users will tweak the registers to turn on all the bits disabled on oem rebadged boards
and adding cards isnt too hard
i think as usual the ram and mpu are the best thing to spend cash on
and im glad to hear you can tweak the mpu speed
although ive learned never to take things too far with bga chips xbox most main boards with issues that 'just stopped working or ylod on playstations etc etc all fixed by 25 sec's @400deg'c smd rework and hot air
the main mpu that get too hot or south bridge and the cpu regulation
ball solder joint fracture... ive just repaired a small intel duo/2 board using this method
it hasnt arrived yet hope it will soon i ordered some acer 2gb ddr for it 800mhz stuff
so full compliment of ram deserves a decent 4 core cpu
this board will take the latest cpu however has a low fsb at only 800mhz
maybe this is where the bottle neck is the most ...
im not too worried about these points
ill need to make an account on the forum above
thanks for posting the link too it here :P
magic_gun
Postby magic_gun » Mon Nov 30, 2009 11:12 am
our lastest hardware 1040 st
Thank you for the interest;
RETRO_Atari 1040 ST With ATARI wireless mouse ( orginally microsoft laser mini mouse in atari mouse case)
CUTE......and Powerfull
computer specs..
zotac 630i _MINI
INTEL D 660 P4
Please check cpu on the net_ http://www.smartoffice.gr/cpu_intel_pd660.htm
3,6GHz d660 cpu Power Mode O_Clock 4,79GHz
2 GB RAM
INTERNAL PSU 450W
Ge-Force 7100
6 ch hd SOUND
320 IDE
WIRELESS INTERNET.802.11g max 54Mbps
WIRELESS MOUSE (two button) ORIGINAL ATARI. ST STYLE
FREE 4 USB PORT
colling methode : air and liquid ( izo-alcholl), Internal temperature of 72 degrees after 2 hours from play the game (call of duty)
Please Check all photo our web site retro mod section http://www.atariturkiye.com
_______________________________________________________________________________________________________________
Thank you for your request and questions,
Below you will find some explanation
**** We have got a
Microsoft Open Licence Program (MOLP)
There isnt any licence issue for this PC
Otherwise
We advice to "PARDUS 2009" OS
We have got a Gnu_Open source_
Please Check on the net.
http://www.pardus.org.tr/
we thing so Visiual option is better than Windows 7
***** You can play All Doom series,Call Of Duty,etc.
Please Check mainboard.
ATARI ST _Retro_ is a "size big" for games.
This unit is for professional PC user.
We can create also for games _lower version_ AMIGA retro.
****** Also we get a lot of MIDI port and software questions.
You can use all EMU program with this unit.
Of course It is a PC.
But,attention!
There is no MIDI port on this device
You can use "Sound Blaster External" unit For MIDI option.
I have no experiment about "Atari Notator" or others.
atariturkiye team..
nativ
Postby nativ » Mon Nov 30, 2009 11:35 am
I thought this was a SonaVista Pro a first sight!
Regards
AtariSince1989
Postby AtariSince1989 » Mon Nov 30, 2009 1:08 pm
I've been looking since a while ago to painting my STE in black, just like yours. I know it sounds silly, but... what kind of paint I should use? Thanks a lot.
AtariSince1989
Postby AtariSince1989 » Mon Nov 30, 2009 1:17 pm
joska wrote:Very nice! That keyboard PCB is very impressive indeed. Why did you choose this instead of just converting the ST keyboard protocol to PS/2 using a microcontroller.
I was thinking about to do a mod to use the STE keyboard on the PC, some kind of like that: http://symlink.dk/projects/c64key/ but more simple, without the ATmega8.
Is that difficult to do? I'm not too much into electronics. Thanks a lot.
nativ
Postby nativ » Mon Nov 30, 2009 1:18 pm
I've used 'Plastikote' Spray's before without lacquer and they have lasted well, with lacquer even longer!
Regards
Ashley
AtariSince1989
Postby AtariSince1989 » Mon Nov 30, 2009 7:00 pm
nativ wrote:Hi,
Regards
Ashley
Thanks Ashley for the info :cheers: . Any special kind of lacquer? No the one my grandmother uses for her hair, I guess :mrgreen:
BoNuS
Postby BoNuS » Mon Nov 30, 2009 7:13 pm
For the best result use nitro cellulose paint, not the synthetic kind of paint which is much softer.
Nitro-base is much harder and more scratch resistant. Best of all is ofcourse 2k CARpaint.
But it is much more difficult to do (real spraygun is needed) an toxic as hell.
http://bonus.home.xs4all.nl/
AtariSince1989
Postby AtariSince1989 » Mon Nov 30, 2009 7:52 pm
BoNuS wrote:For the best result use nitro cellulose paint, not the synthetic kind of paint which is much softer.
Wow, that's sound like high technology chemistry to me :P
With a quick search on Internet, I have found that that nitrocellulose paint is used on guitars. Have even found nitrocellulose spray paint, do you recommend it? Does need lacquer as well? Thanks a lot BoNuS.
magic_gun
Postby magic_gun » Mon Nov 30, 2009 8:37 pm
@atarisince1989
electro-chemical process (plastic on the aluminum and copper on anodized Finally) coated is best, but I think is too expensive.
approximately 500 usd as a case st 8O
cellulose paint and varnish on the successful results but also gives
st case of electro-chemical :)
amiga case is painted :)
thanks
AtariSince1989
Postby AtariSince1989 » Mon Nov 30, 2009 9:12 pm
magic_gun wrote:@atarisince1989
Aye, I think cellulose paint and varnish will do for me :mrgreen: Thanks a lot everybody for the information.
Postby joska » Mon Nov 30, 2009 10:16 pm
I have made such an adapter. Using a microcontroller like the Atmega is definitely the easy solution. I've made such an adapter using an Atmega168 so I can use a TT keyboard with my TT. PM me if you're interested in details.
karlm
Postby karlm » Wed Dec 02, 2009 1:54 pm
I'm assuming that is a typo there joska - i would hope a TT keyboard works with a TT ... 8)
Postby joska » Wed Dec 02, 2009 2:13 pm
karlm wrote:
joska wrote:I have made such an adapter. Using a microcontroller like the Atmega is definitely the easy solution. I've made such an adapter using an Atmega168 so I can use a TT keyboard with my TT. PM me if you're interested in details.
:-) You're right, should say "TT keyboard with my Milan".
