dexterslab wrote:Started the flash, it then asked to power off and on the idsc board, it then said : "ROM write error. or DIP-SW error."
wongck wrote:dexterslab wrote:Started the flash, it then asked to power off and on the idsc board, it then said : "ROM write error. or DIP-SW error."
You need to remove the power.
When it ask you to power on, you need to set the jumper to normal, then put the power back on.
dexterslab wrote:ahh, got it... flashed ok now to 1.27
dexterslab wrote:i still get the two bombs bus error!![]()
not much left to try now, only hardware problem in the TT
wongck wrote:May sound daft, but leave it for a night and it may work after that.
may be some electronic needs resting after the flashing.
dexterslab wrote:need to do some tests with other utils but the ICD RATEHD program says 1.8Mbyte/sec, which is close to twice as fast as the old quantum drive that its replaced, but then that dates from 1994.
dexterslab wrote:i am also tempted to try and mount the ultrasatan inside the drive enclosure, but lack of internal asci port will make for some interesting wiring, so we'll see
