Sound capabilities of the Firebee
Postby simonsunnyboy » Sun Jun 17, 2012 4:47 pm
Which known Atari audio devices are available on the Firebee?
According to a Wiki atleast the YM2149? Is this correct?
How about STE compatible DMA audio or the Falcon Audio subsystem?
Simon Sunnyboy/Paradize - http://paradize.atari.org/ - STOT: http://www.npoi.de/stot/
Jabber: simonsunnyboy@atari-jabber.org
Re: Sound capabilities of the Firebee
Postby Orion_ » Sun Jun 17, 2012 5:24 pm
I don't know about ym2149, but the Falcon DMA is fully working using xbios function !
`^-._ website - youtube - Atari STe 4MB + HxC SD Floppy :: Falcon CT63 @96Mhz 14/128MB + Zip + PS/2 adapter + Hydra Ethernet !
Orion_
Postby simonsunnyboy » Sun Jun 17, 2012 5:48 pm
I have never used the Falcon XBIOS routines for audio sofar. Is there a guide or manual available about its capabilities beyond what I can find in tos.hyp?
Postby joska » Sun Jun 17, 2012 5:56 pm
The Firebee has a YM that's fully (and from what I can tell perfectly) emulated in the FPGA. It also has STE DMA sound thanks to some software trickery (transparent to the user). There is no Falcon sound *hardware*, but there is XBIOS support for the AC97 soundchip. This XBIOS is GSXB compatible. See http://assemsoft.atari.org for docs on GSXB.
Firebee - Milan060 - Falcon040 - Falcon030 - FreeMiNT - XaAES - STM - STE - Amiga 600 - Sharp MZ700 - MSX - Amstrad CPC - C64
Postby simonsunnyboy » Sun Jun 17, 2012 6:02 pm
Having the YM sounds great already :)
"Software" trickery for the STE DMA sound? Does it intercept reads and writes to the associated hardware registers?
Postby Orion_ » Sun Jun 17, 2012 6:17 pm
This is what I use for sound:
Init:
   if (Locksnd() != 1)
      return (false);
   SoundBuffer = Mxalloc(SOUND_BUFFER_SIZE, MX_STRAM);   // Malloc in STRam !
   if (!SoundBuffer)
      Unlocksnd();
      return (false);
   Settracks(0,0);
   Setmontracks(0);
   Setmode(MODE_MONO);
   Devconnect(DMAPLAY, DAC, CLK_25M, CLK_25K, NO_SHAKE);   // 24585Hz
   Setbuffer(PLAY, SoundBuffer, &SoundBuffer[SOUND_BUFFER_SIZE]);
   Buffoper(PLAY_ENABLE | PLAY_REPEAT);   // Play in Loop -> Ring Buffer
   return (true);
DeInit:
   Buffoper(0);
   Mfree(SoundBuffer);
   Unlocksnd();
Orion_
Postby joska » Sun Jun 17, 2012 6:20 pm
simonsunnyboy wrote:"Software" trickery for the STE DMA sound? Does it intercept reads and writes to the associated hardware registers?
If I understand this correctly there are dummy registers in the FPGA that are monitored by an interrupt driven routine. The AC97 is then set up accordingly when these registers are written to.
Postby simonsunnyboy » Sun Jun 17, 2012 6:27 pm
Thanks for the explanation! So compatible HW registers are there but the actual processing is done by the modern day IC part and there is no audio generating circuit otherwise designed into the system?
@Orion_: Thanks for sharing your code, i have also taken a look at Ozk's website. It seems to me that this is the new interface to allow hardware independant audio access? So that an additional hardware driver has to provided? Some ES1371 for the Hades with PCI card and something AC97 compatible for the Firebee?
Postby Orion_ » Sun Jun 17, 2012 6:37 pm
I don't know about GSXB, I'm just using xbios functions, and this is working on both falcon and firebee without modification
Orion_
Postby simonsunnyboy » Sun Jun 17, 2012 6:46 pm
Oh really. Now you see why asking for something beyond tos.hyp as this only lists a couple of calls as being available on the Falcon. My question remains valid: is there any combined documentation available for the Falcon Sound XBIOS?
Postby joska » Sun Jun 17, 2012 7:05 pm
Postby simonsunnyboy » Sun Jun 17, 2012 7:21 pm
Ahh thanks, I didn't have a deep look yet but it is probably exactly what I have been missing sofar. :mrgreen:
Postby nativ » Sun Jun 17, 2012 8:41 pm
There are the XBIOS Docs relating to Milan sound somewhere... I recall downloading some thing about it all... few years back!
Atari STFM 512 / STe 4MB / Mega ST + DSP / Falcon 4MB 16Mhz 68882 - DVD / CDRW / ZIP / DAT - FDI / Atari Jaguar / Atari Lynx / Atari 7800 / Atari 2600 / Atari XE 130 - SD Card
soundcloud.com/nativ ~ soundcloud.com/nativ-1 ~ soundcloud.com/push-records
nativ
Postby joska » Mon Jun 18, 2012 7:02 am
simonsunnyboy wrote:Thanks for the explanation! So compatible HW registers are there but the actual processing is done by the modern day IC part and there is no audio generating circuit otherwise designed into the system?
Correct. The only thing that *generates* audio in the FPGA is the YM. DMA sound is done by the AC97 and the ColdFire DMA.
Return to FireBee
Users browsing this forum: CommonCrawl [Bot] and 0 guests
