PureC VeryVery Slow stdio implementation ?
Postby DrCoolZic » Wed Dec 16, 2009 10:28 am
I was using standard stdio call for copying files: fopen(), fread(), fwrite()
Here is the the bare bone loop with no error checking to copy a file (where BUFSIZE is 100K):
      /* copy the file */
      start_time = timer();
      elapsed();
      while(!feof(src)) {
         count = fread(buffer1, 1, BUFSIZE, src);
         hp->info.src_time += elapsed();
         fwrite(buffer1, 1, count, dst);
         hp->info.dst_time += elapsed();
      printf("%lu msec. (R+W)\n", timer() - start_time);
And here is the output for a test binary files of size 100, 1000, 10000, 100000, 1000000 bytes
As you can see above 10K the timing seems VERY VERY VERY unreasonably long :evil: :(
I therefore decided to replace the stdio calls by GEMDOS calls:
      /* copy the file */
      elapsed();
      do {
         scount = Fread(src, BUFSIZE, buffer1);
         dcount = Fwrite(dst, scount, buffer1);
      } while ((scount == BUFSIZE) && (scount >= 0) && (dcount >= 0));
      if((scount >= 0) && (dcount >= 0))
      else
         printf("%lu msec. Error Processing File\n", timer() - start_time);
I have rerun the exact same test on the exact same partitions:
Speed execution for large file is now 10-20 times faster !!!! :D
How is it possible that PureC stdio is so inneficient ??????
I'd like to hear your experience on PureC lib :wink:
Re: PureC VeryVery Slow stdio implementation ?
Postby joska » Wed Dec 16, 2009 10:40 am
DrCoolZic wrote:How is it possible that PureC stdio is so inneficient ??????
I have never done any tests like this, but it doesn't surprise me that there's problem with a library that has not been updated/bugfixed since 1990 ;-) You might want to take a look at the stdlib in the ACHH distribution. You should be able to use it with PureC straight out of the box.
Postby DrCoolZic » Wed Dec 16, 2009 10:58 am
joska wrote:You might want to take a look at the stdlib in the ACHH distribution. You should be able to use it with PureC straight out of the box.
What is theACHH distribution and where can I find it?
Jean
Nyh
Postby Nyh » Wed Dec 16, 2009 11:02 am
DrCoolZic wrote:I was using standard stdio call for copying files: fopen(), fread(), fwrite()
      /* copy the file */
      elapsed();
      while(!feof(src)) {
Just use:
fread(buffer1, BUFSIZE, 1, src);
instead of
You are reading BUFSIZE elements of size 1. Reading one element of BUFSIZE is a lot faster.
Hans Wessels
Postby joska » Wed Dec 16, 2009 11:06 am
http://members.chello.nl/h.robbers/
Postby DrCoolZic » Wed Dec 16, 2009 12:18 pm
joska wrote:http://members.chello.nl/h.robbers/
Very interesting. I need now to look at it in more detail
Thanks Jo
Postby wongck » Wed Dec 16, 2009 12:22 pm
Nyh wrote:Just use:
instead of
Hans Wessels
Yes, I suggest you try Hans's suggestion.
Instead of going to the I/O to fetch a byte for X number of times, it should be faster to fetach X bytes once.
Of course, it's not going to the real I/O but via the buffers.
Postby DrCoolZic » Wed Dec 16, 2009 12:33 pm
Nyh wrote:Just use:
instead of
Hans Wessels
Humm. Rather unusual usage! I am trying to read bin char and therefore size is 1. Calling the other way around will return 1 or 0 (less than BUFSIZE char remaining) and do not get you the actual count of read elements when returning 0.
In term of performance it should really not matter as any decent implementation would anyway read (count * size_elem)
Common ANSI definition for the function is to call getc() but of course actual implementation differs
Actually following the pointer given by Jo I looked at the implementation (download source & look at stdio.c) in AHCC:
size_t fread(void *data, size_t size, size_t count, FILE *fp)
   size_t n, m, lsiz;
   short f, c;
   f    = fp->_flag &= ~_IORW;
   lsiz = size;
   n    = count * lsiz;
   if (f & _IODEV)                     /* device i/o */
      for(m = 0; m < n; ++m)
         if ((c = fgetc(fp)) == EOF)
            break;
         *((char *)data)++ = c;
   othw                           /* file i/o */
      fflush(fp);                     /* re-sync file pointers */
      m = Fread(fp->_file, n, data);
   return m > 0 ? m / lsiz : (errno = m);
and as expected it does a call to Fread with n = (size * count) and therefore in term of performance calling it either way is the same.
This seems the ovious way to implement on Atari and I really wander how it was implemented in PureC
Postby wongck » Wed Dec 16, 2009 1:30 pm
DrCoolZic wrote:Humm. Rather unusual usage! I am trying to read bin char and therefore size is 1. Calling the other way around will return 1 or 0 (less than BUFSIZE char remaining) and do not get you the actual count of read elements when returning 0.
yes, if you are using it to count the number of elements read, then you are forced to use only 1 way and not the other.
DrCoolZic wrote:In term of performance it should really not matter as any decent implementation would anyway read (count * size_elem)
Ok I admit it, the only time I actually timed the fread/fwrite was on a DOS machine 8O , fetching/putting data from/to the network and HDD.
If I buffer my read/write from/to the network, i.e. writting/reading from/to the HDD in a large chunk I get performance increase vs writting/reading many times in small chunks.
Even I have used it many times in Atari, back when i was programming, I did not worry about the performance as it was a hobby. :wink:
Nyh
Postby Nyh » Sat Dec 19, 2009 1:56 pm
DrCoolZic wrote:This seems the ovious way to implement on Atari and I really wander how it was implemented in PureC
I had a short peek with the debugger and it seems Pure C just uses a loop to fetch every element.
Maybe we should patch the Pure C library on this point?
Hans Wessels
Postby DrCoolZic » Mon Dec 21, 2009 1:30 pm
Hans Wessels
Thats what I thought. I looked for infromation about the fread implementation. Seems like ANSI define it as loop of getc() command/macro. But of course most implementation do better.
Would be nice to have a patched version. However using GEMDOS call fix the problem. Only you cant mix GEMDOS and stdlib calls;
Nyh
Postby Nyh » Thu Dec 24, 2009 4:15 pm
DrCoolZic wrote:Thats what I thought. I looked for infromation about the fread implementation. Seems like ANSI define it as loop of getc() command/macro. But of course most implementation do better.
I disassembled the fread() from Pure C and it follows the ANSI suggestion. It is indeed a loop of getc() commands. So the element size and count have a very low impact on fread() speed.
Before I change implementation O have to carefully study the effect of the various file modi. Read only and write only are simple, but RW might be tricky. I have to make sure the FILE handle of Pure C will be OK after my optimized fread() call.
Hans Wessels
Return to “C / PASCAL etc.”
