fastest way to play ym music on ST
Nyh
Postby Nyh » Fri Nov 26, 2004 11:57 am
Gunstick wrote:I think you did not get the reason for this thread. We discuss how we can create a space efficient but still fast playable music format.
I know. How much space do you want to trade for more speed? Or how much speed do you want to trade for smaller data? I usually go for first max speed.
p01 wrote:That way, the SOS tune ( an example picked completely at random Wink ) takes 27,708 bytes instead of 29,809 bytes if the bitfield of all the registers is always stored.
If you are coding for such random tunes as the SOS tune you better first have a look at the data:
reg update count
 2   4816
 9   2980
 3   2573
 7   1715
 4   1230
10   1102
 0    873
 1    807
 6    177
11    143
 5     67
13      0
12      0
 8      0
Registers 8, 12, 13 are not updated so no need to write code for it. Reoder the registers on occurence. You might consider to couple updates to registers 0 and 1 (they both are the frequency of channel A) then you can pack the most frequent registers into 7 bits and only need an extension byte 387 times at max. (Updating registers 0 and 1 as an pair costs 66 bytes extra but saves at least (807-387)=420 extension bytes.)
Warning: I didn't check whether the data I analysed was indeed SOS by Mad Max. I just grabbed the music data in the source directory from a screen that should contain SOS as music. But who knows what happened to that directory the last 12 years?
Nyh
p01
Postby p01 » Fri Nov 26, 2004 12:11 pm
:P I tried to make my routine rather general, but for the sprite record thing, every nop and byte saved are welcome. Thank you for pointing the re-arrangement by number of updates.
[edit] with this improvement the SOS tunes takes 24,794 bytes [/edit]
megar
indeed
Postby megar » Fri Nov 26, 2004 1:07 pm
I've already picked up that. (registry 8, 12 and 13 not used). I was planning to use this trick in my soon-to-be-released sprite record contest attempt.
But, 3 to 4 nop by vbl, it is not so important anyway, so I think that most code that have be published here is appliable.
Gunstick
Re: indeed
Postby Gunstick » Fri Nov 26, 2004 7:04 pm
megar wrote:I've already picked up that. (registry 8, 12 and 13 not used). I was planning to use this trick in my soon-to-be-released sprite record contest attempt.
I'm not shure that 12 and 13 are not used because the SOS tune is using the envolope quite heavily, it's at least once used for initialization.
Make shure your playerroutine is actually working correctly and compare the tune with the original. E.g. some of the released sprite demos don't use the envelope and just sound wrong.
My aim is to create an interchangeable and standard fileformat. The idea of reordered registers by usage is good, but perhaps a little overkill.
It would be nice if Nyh could check out some other songs for register usage.
I guess that the following grouping would be useful:
Use 1 bit for each of the frequency registers (3bits) then register 7,8,9,10 (4 bits) and last register 6 (noise frequency). Noise is 5 bit, so the 3 top bits can be used for next values: envelope frequency (regs 11,12) 1 bit and envelope type 1bit. Then we have 1 bit left. If it's set to 1, we come to the "extra features" like SID, digits or end-of-song.
e.g:
01100011     ; freq channel B and C, volume C and noise
bbbbbbbb     ; channel B freq
0000bbbb
ccccccccc     ; channel C freq
0000cccc
0000cccc     ; volume C
100nnnnn   ; noise and continue: 100 = envelope freq, no reg 13, end
eeeeeeee       ; envelop frequency
eeeeeeee
..... (next VBL)
Now that I think of it, the frequency registers are 12 bit, so we can use already there the noisefreq "extension".
So another idea is not to use at all a bit-field, but store that info with the data. Each VBL we read a byte, if none of the top 3 bits is set, there is no frequency register to be modified.
If a bit is set (7,6 or 5), we store the data into register 1,3 or 5 and then copy the next byte into 0,2 or 4 respectively.
If there's another bit set (6 or 5) do the same again.
This means if frequency A and C has to be modified, the first byte will have top bits like 101. If it's B and C it will be 011 etc...
And finally if bit 4 is set, there's more data, else we have finished.
0111bbbb   ; regs b&c and more...
0000cccc    ; channel C freq
cccccccc
00100100  ; volumes ABC, reg6, reg7, envfreq, reg13, 'more'
0000cccc   ; volume C
eeeeeeee    ; envelope freq
eeeeeeee
.... (next VBL)
So: play nothing is just $00
Modify something but not frequency is %00010000
Discussion open: shall we continue on this way? I mean, is there someone coming up with a fast routine to decode this?
Or other crazy suggestions?
Georges
p01
Postby p01 » Fri Nov 26, 2004 7:46 pm
For the informations, the number of updates per register in the SOS tune ( which counts 6150 frames ) are:
    [2] => 5442
    [9] => 2994
    [3] => 2575
    [7] => 1717
    [4] => 1232
    [10] => 1216
    [0] => 1003
    [1] => 937
    [6] => 178
    [11] => 144
    [5] => 68
    [13] => 1
    [8] => 1
    [12] => 1
/!\ the registers are set at least one time, thus the 1s for the registers #13, #8 and #12.
My routine with the tune shrinked to 24,794 bytes replays the tune correctly. And as you can from the occurence of updates, the second part of my player is only executed 937 times among the 6150 frames ofthe tune.
As for making a standard player routine, it's possible to put the order of the registers in an header and auto-modify the player routine during the init process.
Nyh
Re: indeed
Postby Nyh » Sat Nov 27, 2004 2:44 am
Gunstick wrote:It would be nice if Nyh could check out some other songs for register usage.
All coders are lazy. My sample routines just sample all 14 registers during songplay. Makes register counting a lot easier.
 * analyse regsiter gebruik songs
 * 14 registers worden gebruikt
 * hoevaak worden ze geupdated?
#include <stdio.h>
#define BUFFER (1024UL*1024UL)
typedef unsigned int word;
typedef unsigned char byte;
byte music[BUFFER];
int main(void)
  long size=0;
    FILE* f;
    if((f=fopen("SOS.dat","rb"))==NULL)
      printf("File open error!\n");
      return -1;
    size=fread(music, 1, BUFFER, f);
    fclose(f);
  printf("size = %li\n", size);
    long count[14]={0};
    long updates=size/14;
    long i;
    byte* p=music+14;
    for(i=1;i<updates;i++)
      int j;
      for(j=0;j<14;j++)
        if(*p!=p[-14])
          count[j]++;
        p++;
      int j;
      for(j=0;j<14;j++)
        printf("Register %2i = %li maal\n", j, count[j]);
  return 0;
Nyh
Nyh
Postby Nyh » Sat Nov 27, 2004 2:45 am
p01 wrote:the registers are set at least one time, thus the 1s for the registers #13, #8 and #12.
Of course all registers are set one time. But if registers after initialisation do not change don't write code for it to change if you are in a hurry. Still think you should combine register 0 and 1 into a pair. Saves you a lot of bytes.
Nyh
Gunstick
Postby Gunstick » Sat Nov 27, 2004 8:26 am
it's not exactly that easy, but for the SOS tune it's working.
LUCKY!
And the problem is the register 13. If writing the same value as before into 13, this causes an effect (restart of wave). You can notice that if you play the SOS tune with the full 13 registers or just with 12 and with an initvalue for r13 at the beginning.
That's why my save routine is now like this (this writes some sort of my YMX format):
         move.l musicsave,a0
         lea ymregisters,a1
         moveq #0,d2   ; which regs change
         move.l a0,a2  ;save curr pointer for writing bitfield
          addq.l #1,a0
         ; special r13 treatment
         move.b #13,$ffff8800.w
         move.b $ffff8800.w,d1
         cmp.b #%0011,d1      ; no 'ULM' value, then it's gotten written to
         beq.s ymr13notmod
         or.b #%1,d2
         move.b d1,(a0)+  ;write r13
ymr13notmod:
         moveq #12,d3   ; remaining regs r0-r12
          moveq #6,d4   ; remaining regs r6-r12
ym_readloop:
          add.b d2,d2  ; shift left
         move.b d3,$ffff8800.w
         cmp.b (a1,d3),d1
         beq.s ymnotmod   ; modified
         or.b #%1,d2      ; set bit if mod
         move.b d1,(a0)+  ; only write this reg
        add.w   d3,d3
        add.w #1,-26(a1,d3)
        lsr.w #1,d3
ymnotmod:
         move.b d1,(a1,d3)
         subq #1,d3
          dbra d4,ym_readloop
          move.b d2,(a2)   ; save bitfield, bit7=reg13, bit0=reg6
          addq.l #1,a0
          moveq #5,d3   ; remaining regs r5-r0
ym_readloop2:
          cmp.b (a1,d3),d1
          beq.s ymnotmod2   ; modified
          or.w #%100,d2      ; set bit if mod
        add.w   d3,d3
        add.w #1,-26(a1,d3)
        lsr.w #1,d3
ymnotmod2:
          move.b d1,(a1,d3)
          dbra d3,ym_readloop2
          move.b d2,(a2)   ; save bitfield, bit7=reg5, bit2=reg0
         move.l a0,musicsave
        move.b #13,$ffff8800.w      ; init r13 with
        move.b #%0011,$ffff8802.w   ; unusual 'ULM' value
       jsr music+8
The trick is to write a silly value into r13 (0011 means hold & alternate, which is very probably never used) and test in the next vbl if it's still there.
The music sounds awful then, but the sampling is correct.
George
gwEm
Postby gwEm » Thu Dec 02, 2004 11:02 am
heres the source for hubbard's driver:
http://www.kubarth.de/sid/index.html
of course its SID on C64, so not totally relevant. but some very interesting principals - fast and a very space effective file format.
i was astonished by its simplicity.
Grazey / PHF
Postby Grazey / PHF » Thu Dec 02, 2004 11:37 am
Oooh the Hubbard driver!
A nice way to waste 15 mins at work... I am reading it now. :D
Gwem: started the cold project.... maybe done tonight..
Grz
http://phf.atari.org - demo coders since 1983
http://sndh.atari.org - Maintainer of the Atari ST chip music archive
http://www.scenemusic.net - Nectarine Administrator
Postby simonsunnyboy » Thu Dec 02, 2004 12:41 pm
Very interesting read - even for those like me who have hardly any knowledge about music. At least it gives a good sketch how playback should work regardless of CPU and synth chip used!
Postby Mug UK » Thu Dec 02, 2004 3:45 pm
This brings to light a conversation a few moons ago with "ADM" who wrote the Mad Max Music Editor Demo.
He was planning on implementing the ability to import JCH songs direct from the C64 .. now *that* would have been fantastic function if he'd ever got that far.
Return to “680x0”
