NVDI - More fonts?
mzry
NVDI - More fonts?
Postby mzry » Sat Dec 24, 2016 6:38 am
Heyas,
My NVDI only has franklin gothic and some other font installed, anyone know where I can get some more?
Thanks,
jfl
Re: NVDI - More fonts?
Postby jfl » Sat Dec 24, 2016 7:55 am
mzry wrote:My NVDI only has franklin gothic and some other font installed, anyone know where I can get some more?
Depending on your NVDI version, anywhere you can get Speedo or TrueType or Postcript Type 1 fonts.
Jean-François
GEMDict – GEMClip
Postby wongck » Sat Dec 24, 2016 8:37 am
NVDI 3 & above, you can just add True Type fonts that you find on the web. Just drop then into your C:\BTFONTS folder.
(some TTF may not work).
Reboot and you may find extra in your font list.
mzry
Postby mzry » Sat Dec 24, 2016 9:08 am
Thx a lot :) I tried it out and works great.
By the way, I can't seem to set my desktop font in Teradesk, it only allows me to use the system font. Do you guys know how I can change that? Thx
jfl
Postby jfl » Sat Dec 24, 2016 9:39 am
mzry wrote:By the way, I can't seem to set my desktop font in Teradesk, it only allows me to use the system font. Do you guys know how I can change that? Thx
Teradesk only accepts monospaced fonts (like GDOS fonts, Courier, or any font with 'mono' in the name).
Jean-François
GEMDict – GEMClip
mzry
Postby mzry » Sat Dec 24, 2016 10:02 am
Ah cool thanks. I got the directory font change to work, but there doesn't seem to be a way to set desktop icon text fonts or the top menu fonts.
Postby wongck » Sat Dec 24, 2016 10:06 am
Are you using TOS or Mint?
For TOS, you need to edit your assign.sys file.
For Mint, you can change with XaAES config file.
mzry
Postby mzry » Sat Dec 24, 2016 10:08 am
Mint, okay I'll check out my XaAES file. Thx again :)
Postby wongck » Sat Dec 24, 2016 10:11 am
Should be inside your EXAMPLE.CNF.
Search for font_id.
Comments explains everything. have fun. :)
Faucon2001
Postby Faucon2001 » Sat Dec 24, 2016 12:36 pm
In fact for both TOS and Mint you can declare the system font in assign.sys once you use NVDI by putting a "s" in front of it, see example below.
PATH = C:\GEMSYS
01p SCREEN.SYS
s monaco08.fnt
s monaco09.fnt
s monaco10.fnt
s monaco20.fnt
02p SCREEN.SYS
s monaco08.fnt
s monaco09.fnt
s monaco10.fnt
s monaco20.fnt
03p SCREEN.SYS
s monaco08.fnt
s monaco09.fnt
s monaco10.fnt
s monaco20.fnt
04p SCREEN.SYS
s monaco08.fnt
s monaco09.fnt
s monaco10.fnt
s monaco20.fnt
05p SCREEN.SYS
s monaco08.fnt
s monaco09.fnt
s monaco10.fnt
s monaco20.fnt
06p SCREEN.SYS
s monaco08.fnt
s monaco09.fnt
s monaco10.fnt
s monaco20.fnt
07p SCREEN.SYS
s monaco08.fnt
s monaco09.fnt
s monaco10.fnt
s monaco20.fnt
08p SCREEN.SYS
s monaco08.fnt
s monaco09.fnt
s monaco10.fnt
s monaco20.fnt
09p SCREEN.SYS
s monaco08.fnt
s monaco09.fnt
s monaco10.fnt
s monaco20.fnt
10p SCREEN.SYS
s monaco08.fnt
s monaco09.fnt
s monaco10.fnt
s monaco20.fnt
21  PCL.SYS
22  ESCP2.SYS
23  CANON.SYS
24  MACPRN.SYS
25  PIN.SYS
26  ATARILS.SYS
31  META.SYS
61  MEMORY.SYS
81  NTOFFICE.SYS
91  IMG.SYS
Philippe
mzry
Postby mzry » Sun Dec 25, 2016 2:25 am
Omg Faucon that's awesome. My user interface looks SO much better now!! Thanks so much :)
mzry
Postby mzry » Sun Dec 25, 2016 2:33 am
Mark_G
Postby Mark_G » Sun Dec 25, 2016 9:52 am
Screenshot ?
mzry
Postby mzry » Sun Dec 25, 2016 10:15 am
https://drive.google.com/open?id=0B6vqgf6MYPD1Z1BCMGdtZDhQXzg
Just a camera screenie. As you can see it's a lot cleaner than the standard system font. Looks very mac :)
Postby wongck » Mon Dec 26, 2016 2:00 am
mzry wrote: Looks very mac :)
I am not a Mac user, so the fonts or icons or both looks like a Mac?
I had used monaco way back when I started using on my 520 ST.
I abandon them now as they look too blocky.
mzry
Postby mzry » Mon Dec 26, 2016 3:21 am
It kind of looks like system 7 to me, kinda Garamond style. Hey man if you have cooler mono spaced fonts I could try it'd be awesome if you uploaded some for me, I'll give them a go.
Postby wongck » Mon Dec 26, 2016 3:40 am
I am using default fonts now.
I don't use icon modes for folder listing, I use text and the folder marker just do not look like 2 squares. I prefer the symbol of the original fonts.
Just me.
