NetUSBee USB driver
Galvez
NetUSBee USB driver
Postby Galvez » Sat Mar 10, 2012 8:39 am
I'm thinking in looking into the NetUSBee network driver to see if I get some idea of what could be failing in the USB driver.
Which network driver is working reliable for the NetUSBee? Are sources available?
Re: NetUSBee USB driver
Postby simonsunnyboy » Sat Mar 10, 2012 1:52 pm
The normal Ethernec drivers for Sting and Mint work 100% with the network part of the Netusbee.
MadMax2023
Postby MadMax2023 » Wed Mar 14, 2012 9:31 pm
I am using NE2KECT2.XIF there http://assemsoft.atari.org/ne2k/index.html
Works very well.
Thanks to continue to search for the usb driver :D
paul92706
Postby paul92706 » Wed Mar 14, 2012 10:16 pm
MadMax2023 wrote:I am using NE2KECT2.XIF there http://assemsoft.atari.org/ne2k/index.html
Works very well.
Hi MM, is the USB driver available for NetUSbee?
Galvez
Postby Galvez » Thu Mar 15, 2012 6:59 am
Works very well.
I guess people is using assemsoft drivers which don't have the sources available.
Postby Dal » Thu Mar 15, 2012 10:31 pm
Have you been in touch with Odd Skancke then?
Galvez
Postby Galvez » Fri Mar 16, 2012 8:37 am
Dal wrote:Have you been in touch with Odd Skancke then?
No, I didn't' try to reach him yet.
I'll do it.
MadMax2023
Postby MadMax2023 » Sat Mar 17, 2012 1:25 pm
Works very well.
The link is for the ethernet driver.
Galvez made an usb driver, but it isn't finished yet, there is an unsolved problem that causes the transfers to crash.
paul92706
Postby paul92706 » Sat Mar 17, 2012 3:00 pm
To: MadMax thanks for that information!
Postby Dal » Sat Mar 17, 2012 4:01 pm
There was also a USB mouse driver but the links to that appear to be dead now
gamer1867
Postby gamer1867 » Fri Jan 10, 2014 8:16 pm
This link might be helpful for a USB driver for the NETUS-Bee hardware:
https://groups.google.com/forum/#!topic ... tTekztDFfU
[PATCH 17/17] [m68k] Atari: NetUSBee tweaks for ISP1160 USB HCD driver (updated patch)
Some tweaks necessary to make the NetUSBee driver work with
both USB ports - something in the NetUSBee design makes the
second port shut down due to overcurrent otherwise. As all
NetUSBee stuff, this is provided by David.
This patch replaces the old patch of the same name - the previous version
would disable overcurrent protection on the EtherNAT!
Hope that helps
gamer1867
Postby gamer1867 » Fri Jan 10, 2014 8:21 pm
I also found the mouse driver here (a .zip file that can be downloaded)
http://www.lotharek.pl/product.php?pid=73
I've included the file itself from that location as a posted attachment to this forum message
Mark_G
Postby Mark_G » Sat Feb 01, 2014 2:46 pm
I attached the mouse driver ver0.90
Mark
Seems to be the same, as the post above.
This one can be deleted.
