Ride the sky with digidrums
All about chiptunes
Moderators: lotek_style, Mug UK, Moderator Team
Grimmy
Postby Grimmy » Wed Jan 07, 2004 12:41 am
Hi there!
I'm looking for an YM5 or 6 of "Ride the sky" with digidrums by TAO (the song is in the UMD8730). I've found the normal & sid version but not the one with digidrums :(
There's a SC68 available (at Ben/OVR web page) including the 3 versions of this great tune but i can't do anything with it, i need it in YM :/
can someone help me ?
thx
Zorro 2
Postby Zorro 2 » Wed Jan 07, 2004 9:12 am
You can ask Tao on the website http://www.creamhq.de/ of Cream.
Member of NoExtra Team
Grazey / PHF
Postby Grazey / PHF » Wed Jan 07, 2004 2:15 pm
Tunes with digi drums are very hard to convert into YM.
I can send you a SNDH of the file if you like ?
Plus I can show you how to play it from your own program.
Grz
http://phf.atari.org - demo coders since 1983
http://sndh.atari.org - Maintainer of the Atari ST chip music archive
http://www.scenemusic.net - Nectarine Administrator
Grimmy
Postby Grimmy » Wed Jan 07, 2004 9:12 pm
SNDH won't help me too :(
I need it as a YM file in order to convert & compact it with my own software so that i will be able to replay it on an old Z80 based computer.
I know how to replay the SNDH and read YM registers with some lines of GFA but how to detect Digidrums ? at least, just a reliable method to detect a digidrum-start on one of the voice, no matter witch sample it is (snare,drums,etc... i could find this later).
I'm used to switch off the tone with Reg7 (mixer) on the voice where i play a sample. I could use it for the detection but i don't know if it work the same with chip player on the Atari and if it will be reliable enought...
Maybe i could do some PEEK somewhere in the replay rout' to find a byte that change if a sample is running or some stuffs like this, but i really don't know much in 68K Asm (i'm lost, too much & too big registers for me ;) )
btw, simple curiosity, does the digidrums support is managed from the tracker used to compose the music or is it a trick added to the replay rout' (for exemple when period register of a voice is 0x000 then the sample number to play is stored in the volume register) ?
dma
Postby dma » Thu Jan 08, 2004 10:32 am
Grimmy wrote:btw, simple curiosity, does the digidrums support is managed from the tracker used to compose the music or is it a trick added to the replay rout' (for exemple when period register of a voice is 0x000 then the sample number to play is stored in the volume register) ?
It depends, a few trackers got this features (and many had it planed but unfinished... :?) but most coder-musicians add(ed) the digi stuff after composing the music.
Return to “Ym rockin'”
