MEGA STE problem
cedrone
MEGA STE problem
Postby cedrone » Sun Jan 21, 2018 7:07 am
I picked up an Atari MEGA STE from the attic, turned it on and it was working.
I do not do anything about it and I was thinking of selling it.
I've cleaned everything up even when opening the case, etc. etc.
When I turned it on again I am left with a white screen, which disappears only after a few minutes, whereas before it started immediately.
Then it seems to me that I do not see the hard drive. I feel this at the beginning that turns, it makes a noise 2 times, but then I do not understand if it works.
The fact remains that the disk icon is not on the start screen.
Can someone help me?
Thank you
Paolo
Moulinaie
Re: MEGA STE problem
Postby Moulinaie » Sun Jan 21, 2018 9:25 am
I had similar problems with a TT.
I just had to push the ROM ICs into their support to get it working again.
Try this...
Guillaume;
cedrone
Postby cedrone » Sun Jan 21, 2018 10:40 am
not solved. and don't see hdd icon. :(
susher
Postby susher » Sun Jan 21, 2018 6:43 pm
Have you put the SCSI ribbon cable in the correct way up? The IDC plug on my TT doesn't have a key on the side so it fits into the drive either way up.
Otherwise you have a dead disk.
cedrone
Postby cedrone » Sun Jan 28, 2018 3:27 pm
Yes, the connections are correct.
could it be the hard disk driver?
this appears before the desktop:
Loading
Atari Hard Disk Driver
AHDI v4.02 Dec 06 1990
NOT Bootloaded
thank you for your answer
Paolo
