Framemeister troubles with my STE
Cogweasel
Postby Cogweasel » Wed Aug 09, 2017 7:59 pm
I just took the plunge and bought a Framemeister, for use with, among other hardwares, my 1040STE. But I am having some sync problems, check the video/photo to see how it looks. I know people have gotten the Framemeister to work with the ST before. Not sure what my problem is here. I am using the Euro connector that was included with the Framemeister (not a JP21!). Do I need to modify my ST RGB cable or do I need a sync stripper maybe? From what I have researched before, I was under the impression that it should work anyway. But of course, it was a bit of a mess researching the Framemeister :)
To make things more confusing; there seems to be some sort of hardware problem with my Framemeister also, as you can see in the video. DHL treated the parcel pretty roughly, so could be thanks to that. So maybe my sync problem is caused by this or maybe a combination of hardware problems and a dodgy RGB signal from my STE? I have contacted Solaris, so hoping they will have some further clues to give. But I thought I would ask what you guys think as well...
Here's a YT link to a video showing the problem
https://youtu.be/SHnhcK_VLPE
leech
Re: Framemeister troubles with my STE
Postby leech » Thu Aug 10, 2017 6:51 am
I'd say pop it open and check solder points as an initial check. Unless of course you have any warranty on it, in which case I'd ask them to fix it.
Cogweasel
Postby Cogweasel » Thu Aug 10, 2017 3:42 pm
Its bought new from Solaris, so I still have warranty. Have been in touch with them and have also filed a damage claim with the freighter. Just a bit curious if the sync problem is caused by the same problem. I was hoping maybe someone here would know if the ST is supposed to work with the Framemeister without any further modifications...
leech
Postby leech » Thu Aug 10, 2017 7:33 pm
I'm sure there are other posts around here, it seems from my brief look around that it should work fine with the Euro SCART adapter.
Cogweasel
Postby Cogweasel » Fri Aug 11, 2017 5:41 pm
leech wrote:I'm sure there are other posts around here, it seems from my brief look around that it should work fine with the Euro SCART adapter.
Yeah, I was under that impression too ... still haven't heard back from Solaris.
EmpireAndrew
Postby EmpireAndrew » Sat Aug 12, 2017 11:02 am
I don't know about your specific issue but the Framemeister does work with the STE if you have the right cable, which needs a resistor.
See this thread:
viewtopic.php?t=30275
1977 VCS Heavy Sixxer (Boxed)
1993 Atari Falcon030, 14MB, Int 4GB IDE2SD, TOS 4.04 -> Atari PTC1426 Color CRT Monitor
Amiga, Mac, DOS, Newton, SGI, Sun, NeXTStation and more!
Cogweasel
Postby Cogweasel » Sat Aug 12, 2017 10:06 pm
EmpireAndrew: On my ST Scart cable I have two cables connected in parallel to pin 20 (Comp video in / Sync in), each connected with a resistor. Composite signal and dedicated sync signal maybe? Not sure really...
