STE no sound BUT press reset and sound appears!
MRAtari
Postby MRAtari » Thu Jun 23, 2011 6:37 pm
STE that has baffled me for ages
it works fine the motherboard but when initially switched on and it goes to desktop there is no sound, not from TV speaker or stereo outputs
press reset, let it reboot and sound appears!
if fact you can kind of hear a "pop" through the speaker when reset is pressed
any idea what i should be looking at?
Re: STE no sound BUT press reset and sound appears!
Postby Dal » Thu Jun 23, 2011 9:21 pm
Sounds like a dodgy reset circuit or a knackered electrolytic cap. The sound chip must be ok if it works reliably after a reset.
Is it only when starting cold the machine fails? Or can it be intermittent with resets?
MRAtari
Postby MRAtari » Thu Jun 23, 2011 10:12 pm
hi
it always does it when switched off and then switched on
even if the machine is warm it will have no sound when switched off and then on again
but press reset and reboot and sounds comes back
MRAtari
Postby MRAtari » Wed Aug 17, 2011 6:47 pm
looking at this board again today
if it has 512k or 1mb memory no sound on initial start (ok on reset press)
with 4mb memory there is sound as soon as machine boots
i guess due to the extended boot delay
can anyone point to a reset schematic link?
thanks
nativ
Postby nativ » Wed Aug 17, 2011 7:19 pm
[quote="MRAtari"]looking at this board again today
if it has 512k or 1mb memory no sound on initial start (ok on reset press) Check yours capacitors on the simms if there are any? have they become loose? having sound on reset might be because they have some sort of static charge keeping them operational!
So it works correctly with 4MB? if so your 512k simms are probably failing! Give Up on1mb go 4mb!!!
thanks
