Compatible USB gamepad or joystick for MiST
Fenio
Postby Fenio » Sat May 02, 2015 8:35 pm
Heloo
I purchased Genius Gamepad but not work witch MiST :-(
What other cheap USB gamepad or joystick would you recommend to 100% smooth functioning ?
Maybe something from the list below (Allegro - polish counterpart to eBay) ?
http://allegro.pl/urzadzenia-wskazujace ... rice_to=25
Thanks for the help :cheers:
Re: Compatible USB gamepad or joystick for MiST
Postby Newsdee » Sat May 02, 2015 9:34 pm
Any generic USB controller should work BUT it has to use the analog joystick axis for movement and not the digital directions (used for the "POV hat" in some joysticks). You can check which one it uses by looking at pad properties in Windows.
Several digital joypads map to analog joystick axis, such as the Buffalo SNES pad replica (my favorite for the MiST) or the various RetroLink replicas of consoles controllers (Atari, NES, etc).
Alessio
Postby Alessio » Sat May 02, 2015 9:35 pm
Not on your list unfortunately - Logitech Wingman Action Pad (2002-3) works for me.
SLiX
Postby SLiX » Sat May 02, 2015 11:33 pm
I use a Saitek P220 which works flawlessly, but this is also an old joypad.
MasterOfGizmo
Postby MasterOfGizmo » Sun May 03, 2015 7:59 am
With the updated USB HID handling that i introduced for the Archie mouse POV hat support is actually the next thing. Initially I plan to have a global option in mist.ini named "usb_joystick_prefer_hat" which (if set to 1) will cause the parser to prefer the hat over the normal axes. This should help with several gamepads.
Edit: This feature has now been implemented and the option to disable the hat usage is:
joystick_ignore_hat=1
Postby Newsdee » Mon May 04, 2015 6:39 am
Great! Can't wait to try my arcade sticks with the MiST!
Postby Newsdee » Mon May 25, 2015 4:13 pm
A new beta firmware is available that adds support for the "POV hat" some controllers use instead of the analog joystick.
Thanks to it I can finally plug my Qanba Q4RAF arcade stick to the MiST and play games with a massive controller :mrgreen:
johey
Postby johey » Fri Jun 05, 2015 7:47 am
I have the iBuffalo SNES control replicas. Works great with the MiST. However, I would really like to remap the buttons. Is there a way I can do that?
Postby Newsdee » Fri Jun 05, 2015 1:18 pm
I have that controller, it would be nice to map start and select for it.
In principle it could be done in firmware if the USB HID parser grabs all buttons (which I think it does). It's something I wanted to toy with for some time but didn't have time to sort out the firmware compilation on Windows yet.
Postby Newsdee » Sat Jun 06, 2015 8:31 am
Managed to get it working. I've mapped start and select properly, instead of X and Y. Its not remappable (i.e. it's baked in the firmware) but at least its much nicer to play NES games with this pad.
I'll try a few more tweaks (maybe map X and Y as reverse A and B) then commit it to the repository for others to try.
johey
Postby johey » Sat Jun 06, 2015 9:49 pm
Very nice work! Beside start and select it would be nice to have Y->B and B->A for the most authentic positional mapping of a NES pad. Anyway I might be able to take a look at the source as well.
farvardin
Postby farvardin » Sun Jun 07, 2015 6:41 pm
hello,
I've installed the latest firmware (150605), and it seems it's not possible to select to use the hat or the stick, it's always the hat (in the previous firmware, 150417 I think, it was the stick). Adding usb_joystick_prefer_hat=1 or usb_joystick_prefer_hat=0 in a mist.ini file doesn't change anything, it's always the hat
I think I prefer the stick, but it's still better to have the choice. Also, being able to change the option from the OSD would be the best (but maybe it's not possible at the moment)
I'm using a ps3 controller.
MasterOfGizmo
Postby MasterOfGizmo » Mon Jun 08, 2015 6:59 am
Please try:
farvardin
Postby farvardin » Mon Jun 08, 2015 10:34 pm
it's the same.
I've tried:
and
usb_joystick_ignore_hat=1
I guess the mist.ini has to be at the root of the sd card...
Postby Newsdee » Mon Jun 08, 2015 11:50 pm
Yes it goes in the root, and make sure the last line is a blank space otherwise it won't recognize the setting.
Here's mine:
[mist]
scandoubler_disable=0
farvardin
Postby farvardin » Tue Jun 09, 2015 11:37 am
ah!
I MiST the [mist] part. I couldn't find any mist.ini sample file so I didn't know how to write the option (I don't know if there are many other cool options for it). I'll try again this evening, I'm sure it'll work this time.
Postby Newsdee » Tue Jun 09, 2015 12:38 pm
Started this, I'll flesh it out later:
https://code.google.com/p/mist-board/wiki/DocIni
Postby Newsdee » Tue Jun 09, 2015 3:10 pm
@johey : try this firmware:
https://mist-board.googlecode.com/svn/t ... _r1115.upg
I've mapped a few controllers that I own:
I'm still working on my Arcade stick... but it would be next: http://i.imgur.com/q8WLLWA.jpg
On the first and third one I've made X to also act as B so thay they can be held in two positions (B-A or X-A). The Famicon pad doesn't need it since the button layout is flat.
farvardin
Postby farvardin » Tue Jun 09, 2015 7:02 pm
thank you for the doc, it'll be useful for future users I'm sure!
So I've used the correct syntax, and now the stick is working again!
(tips: maybe a mode with both input at the same time, if possible, would be useful, it would prevent to remove the sd card and modify it from a computer when you want for example to use the NES core, and later the Atari St core...)
MasterOfGizmo
Postby MasterOfGizmo » Thu Jun 11, 2015 2:10 pm
Yes, that's actually not that hard to implement. I'll add that once I finish my current project (support for rs232 over a RS232/USB cable to allow to use old rs232 peripherals with the mist under Atari ST core).
Postby Newsdee » Fri Jun 12, 2015 1:34 am
I can have a look at that; I'll make hat override the analog stick only when it is pressed. Will try to get a beta firmware done this weekend.
MasterOfGizmo
Postby MasterOfGizmo » Fri Jun 12, 2015 1:38 pm
Newsdee wrote:I can have a look at that; I'll make hat override the analog stick only when it is pressed. Will try to get a beta firmware done this weekend.
Sounds great. Let me know if you need help ...
Postby Newsdee » Fri Jun 12, 2015 4:21 pm
That went much better than expected :D
Try this new firmware: http://mist-board.googlecode.com/svn/tr ... _r1137.upg
Changes:
  • Now the joystick hat will only override if pressed
  • Much better mappings for Qanba Q4RAF arcade joystick
NML32
Postby NML32 » Fri Jun 12, 2015 4:38 pm
Changes:
Sorry, I a little embarrassed :oops: what is the "hat" stuff that everyone talks about?
Thanks,
Mark
Postby Newsdee » Fri Jun 12, 2015 9:35 pm
It's called like that because on analog joysticks for flight sims there is a "POV hat" that is essentially a mini digital joystick.
USB HID assumes that all controllers are joysticks and expects an X and Y (analog) axis value for directions. It then expects a series of buttons, and optionally it allows representing a POV hat as a separate structure. Digital gamepads / joysticks usually map themselves to analog X/Y axis (giving a fixed value). But a few controllers like the Qanba do not use analog at all, and instead map directions to the POV hat.
The feature that Till added allowed these devices to work with the MiST, but originally the override was total (i.e. the analog stick was ignored). I just tweaked it a bit so that both inputs work together, allowing you to use either if a controller has both.
